D-Link DWA 131E Usb Wifi Adapter does not work on ZorinOS Lite. It shows the connections but upon connecting it just shows that it's loading then says Disconnected: You are now offline (Wireless Network).
Can someone help with this issue?
This sounds like more than one Wifi Module (driver) is installed and they are conflicting with each other.
Can you relay the terminal output for
sudo lshw -C network
and
lsusb -t
