whenever im in a fullscreen app, the dash space cuts the app and shows the desktop if u get what i mean
So, if that's disabled - your dash will remain visible like the old OSX style dash.
But, not a bug!
i meant the whole horizantal dash area where my wallpaper is visible, i just want to show the dash
So, You want that Your Windows is in Full-Screen Mode and Your Dash is permanently over it? As far as I know this is not makeable.
But You could play a little bit in the Settings and set it to auto-hide or something similar named and then it pops up when You go with the Mouse at the bottom of the Screen.
I guess that would be a change from "autohide disabled" (as per thread title) to "autohide enabled".
I think You have to enable this seperately. But I'm not sure.
Click the box in Dash settings that says 'Panel mode: extend to the edge of the screen'
