Dash/Panel organization
Greetings,
I am using a wide screen monitor and I prefer my taskbar/dash/panel on the left side. Is there:
  1. A method to organize these icons horizontally?
  2. Shrink the icons on the Dash to fit more on the screen?
  3. Not have all the windows brought to focus when scrolling down in the dash? (recall I have my dash/panel on the left side of the screen)
    I played with an extension from GitHub but it didn't seem to perform as expected.
    I am OK with upgrading to Zorin Pro in order to get more flexibililty if it will include some of these options.
    I am also OK with working with a DEV to build a custom app/plug-in/extension. (I was a Tester at Micros**t at one time.)
TIA
You mean each Icon individually or the whole Group?
The ones that are vertical. It would be nice to have 2 rows horizontally.
TIA
@Griggster
Hi, if you meant you wanted to move the taskbar to the left or right sides of the screen, then now you have that option with the latest ZorinOS 18.1 update.
You'll find it in taskbar settings > position > panel monitor position.
