Davinci Resolve not working
Yes, the instructions are here:
https://amdgpu-install.readthedocs.io/en/latest/
The package can be downloaded here:
https://drivers.amd.com/drivers/linux/amdgpu-pro-20.20-1098277-ubuntu-20.04.tar.xz
It will save to your home Downloads folder. Open Downloads, then right-click the amdgpu...ubuntu-20.04.tar.gz and select extract here.
Double click the extracted file to open it, then find the amdgpu_install script.
all amd driver are Open Source just nvidia are not
Ah, right.
I almost forgot that important small detail.
Thanks for reminding me of that.
Some Vulkan and AMDGPU are open source
https://wiki.archlinux.org/title/AMDGPU
Radeon drivers are proprietary:
Proprietary AMDGPU-PRO drivers. WARNING At the time of writing, the proprietary drivers haven't been released for Ubuntu 20.04 yet.
https://www.amd.com/en/support/kb/release-notes/rn-amdgpu-unified-linux-20-45
By clicking the Download button, you are confirming that you have read and agreed to be bound by the terms and conditions of the End User License Agreement (“EULA”) linked to this note for use of AMD Proprietary OpenGL, OpenCL™, and Vulkan™ drivers provided by this download. Open source software is also provided and is subject to the terms and conditions of the licenses included with such software. If you do not agree to the terms and conditions of these licenses, you do not have a license to any of the AMD software provided by this download.
Interestingly, AMD donates to Solus; yet provides poor Linux support. It is a long-standing point of contention.
oh yeah, that's normal, Adobe also donates to Linux projects I think, and yet they give... well, 0 support, I think it's just that they probably use it on the server side or something like that
Or that gives them a good corporate image.
Hey sorry it took so long for me to try it, I've been pretty busy lately, so, Itried installing the AMDGPU-PRO drivers and I got this error:
Unsupported DEB-based OS: /etc/os-release ID 'zorin'
I tried installing with the following command:
./amdgpu-pro-install -y --opencl=rocr,legacy
AMD reused an easy template for the installer which only looks for the most common Distros.
To get around this, you can open the installation file in a text editor and change "ubuntu" to "zorin" which will allow the installer to run all the way through.
well I'm glad I made a timeshift because my desktop just broke lmao
Broke how?
like this: http://imgur.com/a/x1UhtTg
Wow. Yes, definitely a Graphics Driver issue, there. You could have removed the Driver.
yeah, but it's fine really, I've got a dualboot with windows, any way I can access zorin files through it?
I've never done it...:
So, did you find a solution? I also used Davinci on windows, i have amd radeon graphics card in my laptop. Have the same error.Screenshot from 2021-11-14 12-35-10
I am trying some other softwares, but the problem is of familiarity, old unfinished davinci projects and also that Davinci has many more features. Does kdenlive or any other software have any features for audio enhancements, noise reduction etc. which are available in Davinci?
