I'm using a fresh installation of the pro version. After going into sleep mode and turning off the monitor and reactivation the machine the desktop seems not working. I just see an empty desktop and nothing else, no icons, no task bar and I can not do anything. I need to restart to use the system.
some similar problem I have when I try to connect via teamviewer. I just see a confused and a kind of distorted desktop.
The most likely cause of gnome-shell crashing after resume is a gnome-shell-extension interfering with the shell.
The only "fix" I know of is to disable all extensions:
sudo apt install gnome-tweaks
Open Gnome Tweaks from the app menu (Tweaks) and then the Extensions tab from the left pane - Then test, re-enabling one extension at a time until you see a crash. This narrows down which extension is causing the trouble.
Once identified, you can then try re-installing that extension or if it persists to be troublesome, removing that extension.
