I shrunk windows 11 pro and installed zorin on the empty space on my SSD with ext4 formatting. For Mount point I selected / and under device for bootloader installation, I selected the main SSD /dev/SDA
Everything works perfectly but did I install it right? or should I have selected the same partition (device for bootloader installation) as I installed zorin OS in this case /dev/sda4 ? Is there anything else I should do or correct?
