Dicors lag when I'm on call
It only happens even when I'm on a call, my pc is slow. It happens on my two PCs, one with the 9th generation i7 and the other with the 6th generation i7
Hi, my pc give mini lag when i'm navigation and when i'm writting.
I currently have the discord open on a call, I am programming in the visual studio code, and I have the docker running in the background with a container. And seeing the System monitor, I'm having peaks in the processor.
And when I hang up the call, everything goes back to normal.
I made a video!
Info of system monitor -> https://i.imgur.com/LvDwzIM.png
Video -> https://drive.google.com/file/d/1_PQwp02hkODKgL280-2YoW7lnDHWeZyE/view?usp=sharing
Are you using discord app or on the web browser?
He is using the Application
Others have complained about lag when using the app, but said that the web browser version works smoother.
I hope that in the version of zorin the 16 improves!
I had that problem as well, it's a gnome problem, not a zorin problem... It has something to do with refreshing the icons... Just found it again Added an exception to updating discord's icon to avoid a nasty memory… · scj643/gnome-shell-extension-appindicator@999b58d · GitHub
You gotta read a bit, but I am sure you'll figure it out how to use it again... I can't remember :smiley:
