So, when I was setting up zorin os 16 , i couldn't connect to the internet and went on with the offline installation. Are there some files or updates or anything i need to download, to compensate that. P.S.: I had updated it once installation completed.
If you were able to connect and run updates post-installation, then you will be fine.
You can double check in terminal with:
Then:
apt list -u
to check if any packages require updating.
Ohh, ok thanks. I'll report you if there's anything more to update.
