After each reactivation from the energy saving mode, this appears:
Did you tried to reinstall Discord? Is it a flatpak?
Manually installed via .deb
Probably a bug on discords end, the internet (google) is full with it.
Personally I've had a lot of issues over the years with Discord and linux (their deb application). If you're running Wayland, you could try X11 and see if that changes anything, but I doubt it.
If I run discord I usually use a browser to just avoid this. I actually use a 3rd party client that works for me much better. I guess you could also try the flatpak of discord and see if that works any better, but I just generally dislike the discord app experience on linux period.
