Or avoid using Etcher to start with
Consensus here is recommended to use Unetbootin (Linux) or Rufus (in Windows).
That's how I got started with Zorin, too! Glad you found a solution and thanks for sharing. I hope you like it and kudos for giving it a try at all even. Best of luck!
Probably those are better options, now that I've experienced it. I know nothing about installing Linux, using this type of programms... By following the official guide about installing Zorin, I ended up almost killing my USB drive. I posted it just in case someone who doesn't know anything about all of this (just like me) can solve their problem
You are lucky.
I lost 2 USB sticks to Etcher
I agree with other's statements in here. If you want Etcher to turn your USB drive into a paper weight, then by all means continue using Etcher.
Or
You could use Rufus or Unetbootin, which are known to NOT damage USB drives.
Or
If you want to burn ISO's successfully, as well as do it 20% cooler. I recommend Popsicle!
After almost loosing a pen drive to etcher I added ventoy to it and now i keep both zorin 16 and ubuntu 20.04 on it.
I think it is the best way to keep iso's for live booting
Paperweight for Lilliput? <-- hello Cervantes
It would be too light for anything for us human!
It went to an e-waste a few months ago.
Our city has a strict rule about E-garbage and we have to take it to city's special depot.
But I will follow your advise if it ever happens again.
