Disk Space Low
New Zorin user here, new to Linux as well.
I installed Zorin Core in a Virtual Machine using the instructions here:
I am unable to download software as I keep getting disk space low messages. The VM was set up for 50gb but in Disk Usage Analyzer I can only see a 10.5gb volume with 1.0gb available.
Parted shows three partitions:
This is probably a no brainer for someone well versed...
I solved this - for whatever reason Gparted did not re-size the partition per my commands. I found KDE Partition Manager and that did the job.
