I've got 2 partitions with shared data and windows that don't seem to be auto-mounting at startup.
If I click on the drive in Files app then it says 'Unable to find /media/john/OS'
But if I go to 'Other Locations' and then click on the drive that seems to trigger the mounting and I can then click on the drive through the shortcut and it works fine.
Hi,
it looks like you are using Gnome disks app and auto-mount is on. That's OK. Also try to bookmark this this partition in the same Gnome disks app. So, partition should be bookmarked and with auto-mount on.
Bookmarking this partition should add small star image on it and everything should look like in the attached image (sorry, I'm far from my computer, so it's just a picture from internet)
I had the same problem with auto-mounting, and it helped.
This makes sense. The default mount location used is under /media/<username>/<drive label>. As per your screenshot, you're using /mnt/<drive UUID>. Which is fine, but if you already had a bookmark for the previous location it would explain why it fails at first.
Thanks all. I think I have it sorted now. Mounted again in /mnt/ and it's accessible right on boot. I think the mistake I made was mounting in /media/, which I'm guessing is treated differently as regards auto-mounting?
