When I try the decrypt the windows partition with dislocker, it seems to fail somehow:
sudo dislocker /dev/nvme0n1p3 …
command produces message:
Segmentation fault
This message is very short and I could not see what the failure/error actually is with this dislocker command.
What version of Dislocker are you using? Is it 0.7?
The dislocker-git is the recommended patched version.
dislocker by Romain Coltel, v0.7.1 (compiled for Linux/x86_64)
Yep- Try using the git version, instead. That should resolve the issue.
I could not find it by the apt search dislocker-git
It looks like “arch-linux”. I’m not sure how to use that.
Also command dislocker-fuse gives “Segmentation fault”.
Please review here: Segmentation fault with Windows 10 Pro 19.03 · Issue #185 · Aorimn/dislocker · GitHub
To install the AUR dislocker-git:
In terminal, please run
cd dislocker-git
makepkg -si
I’m not sure what it is doing, but it looks failing in the last part with the makepkg:
jari@ENVY-17:~/dislocker-git$ makepkg -si
makepkg: command not found
Ah, I am sorry, that was an AUR command.
Used to be Fribid… That was before my time. Let me try to find out what to do- give me a bit.
Anything of use here?
