Display brightness level numerically - laptop built-in display
Does anybody know - is it possible to display (ideally, set) the laptop display brightness to an exact level?
Usually I have my external monitor, however for photo editing when just on laptop I would really like to see what level the brightness is at, rather than just the slider position, so as to maintain consistency.
I'd also looked at a few utils for setting display brightness exactly, but wasn't sure if any worked with laptop built-in display,
I am on Zorin 17.3 with Wayland (I've stayed on it as the default. In fact I experienced display issues when I did try x11 a few times).
Thank you!
You can try it with brightnessctl
sudo apt install brightnessctl
Then run
brightnessctl info
and it shows the current brightness as number.
To set a specific brightness number, e.g. 5000:
sudo brightnessctl set 5000
Replace the number with a value you like. The brightnessctl info shows you what the highest value is that you can set.
I tested it in Zorin 18 on my laptop. It worked in Xorg and Wayland.
Maybe this Gnome Extensions suit You:
If you want to manage the brightness on laptop and external monitor this gnome extension can help. You can enable to show a value label in the extension.
Thank you, all great solutions.
I'd like to set both Forpli and Ponce-de-Leon as solutions if I could.
brighntessctrl allows for finer granularity, but the extension is quicker and probably close enough.
Side note: I had searched in extension-manager for display, brightness and a few other terms. Nothing useful showed up, or all that did were deprecated. I even searched in there just now for 'discrete brightness' and - no search result.
Brilliant. Easily solved, and thank you.
