Display Issue on xfce
I don't know how I can explain this by words so I am sharing a video.https://drive.google.com/file/d/1QLaJM1_HUE6RhNEiU2BBS4_r6Ss_MAgq/view?usp=sharing
(You might only be able to see the problem if you are on full screen and also mute the audio if you don't want to hear wired click noises. Don't know why the screen recorder enabled my mic in-between)
Had trouble uploading a video here. I don't know if it is because the video is in the wrong file format or what. Okay I will get to the point. These things only appear when I am in xfce and on full-screen. It doesn't happen all the time. Only on certain times like when I press a button. Help, it is getting worse day by day :frowning:. I use Zorin 16 Core xfce. Thank you in advance.
Uploading video's is easy...
Upload your video's to Youtube. Then grab the URL link to your video. Paste the URL link into this message box, and the forum will automatically parse the video.
Type whatever message you need in the message box as well, then hit submit. Easy. Someone will be with your shortly to answer your original issue.
Can you please supplement the video with a description of what to look for? I watched the video several times, but I cannot figure out what it is I am seeing. You created a button to demonstrate, giving a pop up each time you pressed the button.
What is the display issue?
Ahhh.... I did not check if people from other devices could see it. I watched the video from another laptop and there I couldn't see the issues either. Maybe screen recorders can't record the issue i'm facing. Just wait a sec I will record a video from a phone and post it here.
This is actually a helpful clue along the way, though.
If the monitor is displaying differently from what the screen recorder shows...
https://drive.google.com/file/d/1EMfKVy-BGRp8neYRfZwg-SOZmVmAqVqO/view?usp=sharing
It is better to mute the audio here too :sweat_smile:
The video quality is bad so it will only show a portion of the actual problem I am facing but you will understand what it is. You see the the prompt window getting cut off, the line which cuts it off actually extend even longer and most of the time there will be a big white Z like shapes on the screen.
Settings > Appearance > Fonts tab
Is Enable anti-aliasing checked?
What is your DPI?
Are you using any Scaling?
For the first question, yes. For the second one, it's 96. For the third one, no i guess.
Sorry, Jeslin, I am in a hurry so I am going to throw some links at you for the moment:
https://techstop.github.io/fix-screen-tearing-xfce/
@Jeslin, what gpu do you have ?
Ah, great you pitched in :slight_smile: @anon96359095.
I was trying to watch the video but something is blocking it and was unable to. If the GPU is Nvidia, I think you have some good idea.
To find out the GPU that you are using, please do the following commands.
Hold CTRL ALT t to enter terminal
sudo apt install inxi
Enter your password. Then type Y when it asks you to.
Once installed, please run the following command...
INXI-G
Please post the results. Here is my INXI-G for example...
sudo lshw -c display works as well :wink:
jeslin@jeslin-Satellite-L510:~$ sudo lshw -c display
  *-display:0
       product: Mobile 4 Series Chipset Integrated Graphics Controller
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       version: 07
       width: 64 bits
       clock: 33MHz
       capabilities: msi pm vga_controller bus_master cap_list rom
       configuration: driver=i915 latency=0
       resources: irq:16 memory:d0000000-d03fffff memory:c0000000-cfffffff ioport:6110(size=8) memory:c0000-dffff
  *-display:1 UNCLAIMED
       description: Display controller
       physical id: 2.1
       bus info: pci@0000:00:02.1
       version: 07
       width: 64 bits
       clock: 33MHz
       capabilities: pm bus_master cap_list
       configuration: latency=0
       resources: memory:d3500000-d35fffff
The INXI-G command did not seem to work for some reason.
Lowercase try...
inxi -G
jeslin@jeslin-Satellite-L510:~$ inxi -G
Graphics:
  Device-1: Intel Mobile 4 Series Integrated Graphics driver: i915 v: kernel
  Display: x11 server: X.Org 1.20.11 driver: i915 resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa DRI Mobile Intel GM45 Express (CTG)
  v: 2.1 Mesa 21.0.3
@Aravisian Info you requested from OP is now here when your ready.
Jeslin, Aravisian is a XFCE wiz IMO. :smiley:
Good news! :grinning_face_with_smiling_eyes: The link aravisian gave me worked or it could be the update i just installed. Anyways the problem is gone and thank you all for helping me.
Thank U Reaction GIF by Amanda
Awww, you are most certainly welcome. :cat2:
I was still digging on google haha. Glad it worked :smiley:
