Display never wakes after screen blank on Wayland/NVIDIA; zorin-appindicator teardown precedes gbm front-buffer failure
On a Wayland session with an NVIDIA GPU, the display does not come back
after the screen blanks. The machine stays responsive but the compositor
can no longer present frames, so a hard reboot is the only recovery.
Does this happen in Xorg, too? If You have Logs, it would be nice when You could post them here.
Never tested on xorg however i have logs from wayland.
i attached an image of a summary of the logs the full log file is over 4600 lines
You could test if it behaves the same on Xorg, too. That could help to know. Then, You could disable the Zorin AppIndicators to see if that helps. Also I see, You use the 580 open Nvidia Driver. Maybe try a non-open One more current Driver Version.
That could help to specifiy the actual Issue more. At least the first 2 Things would be a fast Test.
I will test these in the morning and get back to you
sorry have been busy this week and weekend with test asap
You don't need to hurry.
Ok i finished testing and the app indicators were not the issue however when i switched to zorg it seems to be functioning normally with a few tests.
