I use Zorin on an older computer. I use it with Simple Screen Recorder to record and save webinars.
The machine is always plugged in.
I have the machine set up with the screen saver turned off.
In the power settings I have the display always on.
When I am trying to record Zoom webinars, the display still goes black.
With pre-recorded webinars I never have a problem.
How can I change something in settings so that the display NEVER goes blank?
Thanks
tom
Have you check Caffeine at Software?
It should prevent from screen goes to sleep during full screen mode.
Here is a old post of mine regarding Caffeine.
It is a very interesting anecdote.
I always used Caffeine successfully when I was running OSX on my HP Elitebook (now it is running Zorin 16).
I also installed Caffeine to a real Macbook I gave to my mother-in-law (OSX is the only OS 90 years old can handle
