Display resize to 125% (as under windows 100-200)
is this possible?
I only found under: Appearance/ Window Scaling
1x (no scaling)
2x (this 200 %, which is too big)
Settings > Screen Display > Click the button ON for Fractional Scaling, Select 125% on Scale. I've done it on my 1440p monitor. Be aware that there could be some apps that dont scale nicely (which is true on any system with the same function)
Edit: this is on Zorin 16 by the way. Cant speak for other versions.
