I can only see the Zorin start button and Taskbar on the primary monitor when I'm in Join Displays mode. I'd like to have it appear on other monitor(s) when my mouse is on that other monitor. In the Apple Mac OS the Taskbar or Dock appears when you move the mouse pointer to the bottom of the screen. Is there a way to do something similar in Zorin?
You can try to toggle the "Display panels on all monitors" setting. If I remember correctly this should display the taskbar on all monitors, but it won't follow your mouse.
Maybe taskbar intelligent-hide would be a workaround for that.
Thank you. The Display panels on all monitors" worked.
Oh, I completely missed that second part of the question...
@bobkaku, you can also have that behavior enabling by enabling the intelligent hide setting which I believe it's under the Behavior tab.
