Hi all, I am on Zorin Lite 15.3. I am running into an issue that only affects me occasionally.
On some reboots the DockerBarX part of the toolbar does not work properly. Sometimes it will be just straight up missing. Sometimes it'll just be a blinking horizontal line. Sometimes my icons will show up but clicking them won't launch the apps. Why is this?! It is driving me nuts. Is there a log somewhere I can look?
Now the weirdest thing about this... this is a fresh install of Zorin 15.3...
I am a Zorin Lite user and I admit - I always remove dockbarx. Partly because I find it superfluous. It does not do anything that the panel does not already offer.
You can try reinstalling it to see if the file corrupted and a reinstall of it fixes that:
Okay, I don't know what I did but now this thing is not working at all. It is just a blinking line everytime I boot. I have tried running the apt command and I have even tried a clean install (on two laptops). What is going on here? Are there any DockBarX alternatives? https://imgur.com/a/2OYmFfj
This is caused by dockbarx not recognizing the panel.
Perhaps your panel is called "panel1" in settings, but dockbarx is looking for "panel0".
You can right click the panel and open Panel Preferences to see what Panel name your panel has.
This often can be fixed by setting the background color from the panel preferences manually, to get dockbarx to recognize them.
In panel settings, when I turn off the opacity of the panel, this part stays the same. Means, this have a different settings. @Aravisian , what do you think?
I am honestly not sure. I can relay what others have experienced, but I personally do not use Dockbarx simply because on XFCE, it is superfluous.
I do not know much about its configuration.
