Does the RX 9070 work on Zorin OS?
Hi everyone,
I have a quick question. In the next few days/weeks, I'm considering buying an AMD RX 9070 XT, and I was wondering if, since Zorin OS has (from what I understand) a fairly old kernel, it works on Zorin or if I should wait a bit until it's supported (given that it's quite new)?
Thanks in advance for your help :smile:
A newer kernel may be required and installed on Zorin, or wait to 17.3 which will arrive with a newer kernel. But if it's new enough I don't know. You're looking for the latest kernel for that card.
I think, there You will need a newer Kernel. Maybe the newest for this.
Okay, I'll see if there's a more recent kernel that supports the card.
Do you have any idea when 17.3 will be released?
You can install the TuxInvader 6.12 kernel, or Liquorix or Xanmod kernel.
Oh thanks, I've already heard of Liquorix but not the others :sweat_smile:, I'm going to read up a bit more to see which would be the "simplest" and "most practical" to install.
Zorin has already announced that 17.3 will not come with a newer kernel after all. They broke their word. Sorry ...
I just installed 6.12 via Ukuu. Makes my system fly even more. My AMD RX 6600 card works great. Unfortunately, Zorin has announced that 17.3 will not ship with a newer kernel (after saying publicly that 6.11 would come with 17.3). Zorin OS 17 will remain on 6.8 until June 2027. Either don't use Zorin OS or install a newer kernel, like how I did. But I don't know how much longer I'll keep using Zorin OS in light of this broken promise. Good luck in any case.
Zorin said this month.
Thank you for your feedback. I don't know Ukuu, so I'll look into it. Have you installed the "basic kernel" or a different one like Liquorix ?
Oh that's a shame :pensive:, but I have to admit I really like zorin's interface. So I'm ready to give it a miss.
Basic. 6.12. Hope this helps.
I understand completely. Am contemplating leaving. A shame.
Thank you all for your help, I think I'll download a more recent kernel with Ukuu :slight_smile:
Ukuu is the Pay-For version of Mainline installer.
Okay, thanks for you tutorial :smile:
