Does Zorin Lite fstrim
Hi
Does Zorin Lite has fstrim for SSD enabled by default?
I run command:
sudo systemctl enable --now fstrim.timer
And nothing happes...
info below:
jesuslinux@jesuslinux:~$ lsblk --discard
NAME   DISC-ALN DISC-GRAN DISC-MAX DISC-ZERO
loop0         0        4K       4G         0
loop1         0        4K       4G         0
loop2         0        4K       4G         0
loop3         0        4K       4G         0
loop4         0        4K       4G         0
loop5         0        4K       4G         0
loop6         0        4K       4G         0
loop7         0        4K       4G         0
loop8         0        4K       4G         0
loop9         0        4K       4G         0
loop10        0        4K       4G         0
loop11        0        4K       4G         0
loop12        0        4K       4G         0
loop13        0        4K       4G         0
loop14        0        4K       4G         0
loop15        0        4K       4G         0
sda           0      512B       2G         0
├─sda1        0      512B       2G         0
├─sda2        0      512B       2G         0
├─sda3        0      512B       2G         0
└─sda4        0      512B       2G         0
sr0           0        0B       0B         0
It is not enabled by default.
You ran timer which will run every Monday starting at 0 hours. So you may not see a response from it immediately.
So how do I enable it?
The fstrim command does nothing
Why do you think this?
It worked.
It will run on the timer ...
Well because I did the same on manjaro and had a reply on the terminal...
Try including:
sudo systemctl start fstrim.timer
