Does Zorin Pro has any validation that needs a licence key?
Hi!
I plan to buy 2 Pro versions and I would like to know if the Pro ISO includes any kind of internal validation that asks the user to enter a licence sent by email.
Zorin OS Pro will be installed without active internet connection in one of the computers.
Thank you!
If you buy the pro version for yourself you are allowed to install it on multiple computers and don't need two licenses.
Thank you replying.
And sorry, but there's still a question that I would like to know: Is any licence key sent by email that needs to be entered in the installation wizard?
Update:
Mmm seems that there's no licence key, at least in Zorin OS 16, so no problem if installing it in a system without active internet connection then?
Usually you have to enter the code sent per Email when you want to download the Zorin pro version.
But surely someone else can tell you more, I don't have the pro version myself.
Ok thank you!
You get an E-Mail with a Download Link for the Pro Version so You can directly download it from there. It also includes a Key for the Case You need Support or You make an Upgrade from Core to Pro.
So, when You download the Pro Version directly from the Link in the Mail, You don't need the Key. But when You upgrade, You would need it.
Thank you for your explanation!
You can install Pro on your personal use computers in your home, as well. So you do not need to buy multiple copies.
