Does Zorin run Fl Studio?
Hello, I’m considering buying Zorin, but I first need to know if it can run FL Studio, a music production Program and if it doesn’t, does it at least run Ableton ? It’s critical for me as I work with those Programs daily. Thank you.
My son runs FL Studio on his copy of Zorin using Wine.
If it was me, I would install Zorin OS and test it out. I know that would mean installing twice, in the end. But still could be worth the trouble.
Thank You ! I will definitely try it out. Cheers
Bitwig runs natively on Linux, incase you weren’t aware of that. Just in case you aren’t stuck to FL Studio.
i keep getting this error when opening Screenshot_2021-06-28_13-30-42 when opening the 64bit version of FL Studio.the 32bit open fine.
any clues?
Is this the guide you following?
No,I didn't install via play on linux
I no longer use Wine (due to a font rendition problem for Japanese characters) but when I did use it in past, I found that 32 bit version apps were easier to install than 64 bit version.
I always used 32 bit version, but I could also imagine some use cases where 64 bit version is required.
