Good evening, I am a new member of the dorum and a new Zorin Os Core user.
My problem is trivial but annoying, let me explain:
often another cursor appears on the screen at a certain point on the screen, like a spot.
Why?
Thanks a lot
Hi and welcome. You are going to have to provide more details than that to get you some help. Perhaps a screenshot? Also - your hardware (type of make, CPU, amount of RAM, SSD or HDD) and what version of Zorin? That way the volunteer folks here on the forum can try to support your issue. Thanks... ![]()
Is it the same Cursor that You use?
P.S: a Screenshot would be nice.
Thanks a lot!
Yes, it's the same cursor
I had to take photos with my smartphone because when I took a screenshot the "double cursor" disappeared
Okay, thank You for the Pictures.
First I would suggest to test if it is a Wayland/Xorg Issue. To control that go to the Login Screen. Click on You Profile so that the Password Field appears. It is important that it appeard. Then You see in the bottom right Corner a Gear Icon. Click on it. There You should find 2 Option:
- Zorin Desktop (that is the Wayland Option)
- Zorin Desktop on Xorg
Which Option is active You can see from the Point Marker. By default it should be the first One. So, change from the active One to the other One by clicking on it and then log in and test if it works.
Thanks for the reply.
It seems to be going well and the problem is solved.
Should I delete Wayland?
If yes, what should I do?
Thank you
Leave it alone. Just use X11 and Wayland is there if you ever need it.
Could this be a problem?
Ho visto questo discussione in cui suggerivano questo metodo:
Wayland is a feature like X11. It is not a problem. Wayland is the future for display management. But for some hardware it can be troublesome. That is why Zorin includes both Wayland and X11. Just use X11 if that works better.
You can do it, but You don't have to. When You change it in the Login Screen it should stay.
No, let it like it is and simply use Xorg. That is the simpliest Way.
Thanks to both of you for the replies.
Mine was a curiosity whose aim was to avoid having to choose between the two at every access ![]()
But nothing can be done
You don't have to choose it on every Access. When You change it once it stays there so long until You change it again. Or falls it back on Your Machine? If yes, then You can make the Change in the custom.conf File.
That's fine, I'm only answering now because I wanted to test the system with xorg and it's no longer giving that annoying "problem".
Thanks for the support.
See you soon
