Zorin OS 17.1 Pro required double input password in lock screen
If show lock screen, I'm enter one password, then one more time Open lock screen enter two. Why? ![]()
Just tried lock screen in Core and don't have that issue. Was this an upgrade from 16.x Pro? I would advise that as you have Pro installed you are eligible for Team Zorin support. You will need to fill out a support request form here:
Hello,
I've had similar issue. I replaced Wayland with X11 and it hasn't happened since.
You can read the following message about how to switch:
You can test it to see if it improves the situation.
I've actually had this before with 17.1 Core - were you in Powersave mode by chance? This only happens when I'm in Powersave mode (laptop, and not always).
Is this a constant; the doubled lock screen?
