I need to download Zorin 15 Ultimate & Zorin 16 Pro (both of which I purchased) via the terminal using wget (or curl), but I can't find the direct ISO links to do that. Any idea where to get those links? The emails I got has links that work in the browser but not in terminal (unless I am missing something!)
Wget uses the same URL and protocol that the browser does.
Please check that you are submitting wget followed by the URL inclucluding the File Name on the end of the url:
I realize that this does not answer your question but...
Why not download the copies using a browser, then?
As far as why it is working in browser but not with wget- that is a bit of a mystery. As Pro (Or Ultimate) is a bit of a special case and not a normal public download, there may simply be a bit of security there that I am not familiar with.
Thanks for your help. I prefer to use the terminal because I have some weird setup in my system that occasionally freezes the browser (Firefox in this case), and I have to kill the process in terminal, which means I have to start the download again and that takes a very long time (12 hours for 5 GB!). But you are right that Ultimate and Pro appear to be special cases as the download URLs expire.
Thanks again!
I just checked something, and you are right: the URL for the free versions is as you initially mentioned, but the paid versions have different URLs. So for Ultimate and Pro wget and curl will not work unless I am missing something.
So if someone a buying a Zorin 16 Pro and share that link that means anybody can get a original a copy or this link have a some time to can be used? I wondering about pirate copies on the websides.
