Drivers triple monitor drivers
Hi i have drivers for monitor they are from here
the file is racer-install_2024-09-05.tgz
inside this file but i have tired to install this with package but it did not install.
I am coming from windows 11. I only need this driver to installed can some help me.
Extract the tar.gz with Right Click > Extract here
Open the created directory racer-install and you will see the .sh scripts for installing files.
I see listed:
evdi-install.sh
RacerDisplay.sh
racer-install.sh
service-installer.sh
Right click on the .sh script you need and select Properties > Permissions
Allow Executing as a Program
Then run the .sh to run the installer.
