[drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma0 timeout, signaled seq
I Didn't experience any issues up to Zorin 16.3. Since fresh installing 17 I'm getting logged out 4 or 5 times a day. Seems to happen when I'm using the touchpad. Doesn't happen while watching youtube etc.
Lots of amdgpu errors in the logs. Any suggestions?
END
16:20:58 kernel: rfkill: input handler disabled
16:20:57 kernel: wlp2s0: Limiting TX power to 23 (23 - 0) dBm as advertised by : : : : :
16:20:55 kernel: rfkill: input handler enabled
16:20:45 kernel: wlp2s0: deauthenticating from : : : : : by local choice (Reason: 3=DEAUTH_LEAVING)
16:20:45 kernel: rfkill: input handler enabled
16:20:45 kernel: [drm] Skip scheduling IBs!
16:20:44 kernel: amdgpu 0000:04:00.0: amdgpu: GPU reset(1) succeeded!
16:20:44 kernel: [drm] JPEG decode initialized successfully.
16:20:44 kernel: amdgpu 0000:04:00.0: amdgpu: SMU is resumed successfully!
16:20:44 kernel: amdgpu 0000:04:00.0: amdgpu: SMU is resuming...
16:20:44 kernel: amdgpu 0000:04:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
16:20:44 kernel: amdgpu 0000:04:00.0: amdgpu: RAP: optional rap ta ucode is not available
16:20:44 kernel: amdgpu 0000:04:00.0: amdgpu: RAS: optional ras ta ucode is not available
16:20:43 kernel: [drm] reserve 0xa00000 from 0xf41e000000 for PSP TMR
16:20:43 kernel: amdgpu 0000:04:00.0: amdgpu: GPU reset succeeded, trying to resume
16:20:43 kernel: amdgpu 0000:04:00.0: amdgpu: MODE2 reset
16:20:43 kernel: amdgpu 0000:04:00.0: amdgpu: GPU reset begin!
16:20:43 kernel: [drm:amdgpu_job_timedout [amdgpu]] ERROR Process information: process pid 0 thread pid 0
16:20:43 kernel: [drm:amdgpu_job_timedout [amdgpu]] ERROR ring sdma0 timeout, signaled seq=3261, emitted seq=3263
START
You are certainly not alone in this, with users on Fedora, Arch and Manjaro also reporting similar issues:
Most respondents mentioned trying later kernels. I wonder if any tried installing an earlier kernel in case the later ones had a regression?
