Dropbox settings
Hello everyone,
I have Zorin 17 and I installed the DropBox client as per the manual. The problem is that, once the application is installed, it's not possible to access the configuration interface where you can also select which folders to sync. The application works, it's present in the bar and it syncs, but clicking on the icon doesn't open the menu for the various options. Does anyone know how to fix this?
Thank you
Hi, see if the solution given here helps:
Have seen other posts about issues with flatpak version of Firefox which is also the version that comes with Zorin 17 by default.
Yoh can now change this for the .deb package.
