Dual boot iMac problem
I have a 2017 iMac which I have upgraded with a 2TB MVNE m.2 SSD as my primary drive with OpenCore and MacOS 17 in addition I have a 1TB SSD.
I installed MacOs on the MVNE driver and did a time machine restore and everything twas running perfectly. So I decided to install Zorin on the other drive. I made an installer and installed Zorin and selected the 1TB hard drive. After the installation was finished I was able to configure Zorin although strangely the sound isn't working.
However.... I re-booted and there is no longer the EFI showing to boot to open core I can only boot to Zorin. If however I install the USB drive with Open core on it the EFI is there and I can boot to the 2TB MVNE drive. Having done so I open open core an it prompts that there is no EFI and asks me if I would like to install it and I say yes and then select the 2TB drive and it appears to work and then says reboot? I click yes and nothing has changed all I see is two options EFI which boots to Zorin and Macintosh SSD which does not boot and it's EFI is no longer recognised.
I then booted up using the USB Drive with Zorin and ran the Boot Repair function. This seemed to do something so I re-booted and now I have three options I have two "EFI Boot" options one with a nice blue icon and the other just looks like a drive and "Macintosh SSD" both the EFI Boot options boot Zorin.
Am I the first to have this problem? What I want to see really is two EFIs one for Mac and one for Zorin. Any suggestions?
The EFI boot icon looks like the OpenCore EFI but it boots to Zorin.
Can anyone help with this?
I'm actually quite lost when it comes to dual boot, especially on multiple drives. Any chance that you can restore to your previous setup? You might need to go over the partitioning manually, instead of using the defaults (if that's what you did?)
