Dual booting Win11 pro and Zorin Core 18 wifi issues
Hello,
I got sick of Win11pro but since I go to college and like to occasionally hit some games I just naturally decided to dual boot Win11pro and Zorin Core 18.
I had created a bootable usb on Rufus (GPT/UEFI) and then I made an empty partition of 70GB on my C drive.
I went with the option of installing along with Windows boot manager and everything rn seems to work except the wifi.
Does anyone know how to solve this?
My specs
• AMD Ryzen 5 7520U
• AMD Radeon Graphics
• 16 GB DDR5
• 512 GB SSD
Did you take a look at Software&Updates >Additional drivers if there is offered a WLAN driver?
Is fast startup in Window's energy settings disabled and fast boot and secure boot in your BIOS?
When you tell us the brand/model of your computer it is easier to find a solution.
Brand and model: Asus vivobook go 15.
Will check settings in BIOS
Hi and welcome.
Can you open a Terminal (Menu | Utilities | Terminal) and enter:
sudo lshw -C network
and post back the results please.
Can You post the Output of rfkill list please? And does Your System run in Wayland or X11? You can check that in Settings>System>Info>Sysstemdetails.
0: hcio: Bluetooth
Soft blocked: no
Hard blocked: no
Le asus-wlan: Wireless LAN
Soft blocked: no
Hard blocked: no
2- asus-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
It’s Wayland
Then try it with switching to Xorg. to do that, go to the Login Screen. Click on Your Profile so that the Password Field appears. When it is appeared, You should see in the bottom right corner a Gear Icon. Click on it and choose the Option ''Zorin Desktop on Xorg'' and then log in.
Update
I did some research and found out that my MediaTek 7902 Wi-Fi card doesn’t support Linux. Now I don’t know which budget External USB Wi-Fi supports Zorin Core 18.
Maybe You could take a Look at the TP-Link T2U Nano.
Will it work out of the box?
What I have read, yes. But to be fair: It were only a couple of Comments for it. You can take a Look at it first. And of Course wait for other Recommendations.
Yup. I have a bit different TP-Link adapter: TX20U Plus. It works okay. But sometimes you need to reconnect it or restart network-manager. Today the network-manager got an update and for while it doesn't failed yet, but I don´t know if it's fixed by the new version.
This one won't work out of the box but it has a quick fix which I shared in this tutorial:
There is a work-in-progress driver here:
