Dual Monitor - Custom layout - Auto save
I'm using zorin pro for many years, It will be great if the "Display" section on configs, save my "Join Displays" layout option automatically (every time it goes back to side-by-side, but I use my external monitor above the built-in screen)
Yes, that really would be a desirable option! At the moment you can only save this setting permanently by switching to XOrg and using the terminal program xrandr (or arandr, that is the gui for it) with a script that is launched at start.
With the flag --above you can set the position. First find out the I.d.s of your monitors by running xrandr in terminal. When your laptop monitor maybe is eDP1 and your second monitor HDMI-1 a possible script may look so:
#!/bin/bash
xrandr --output HDMI-1 --above eDP-1
or if the second monitor is connected via Displayport
#!/bin/bash
xrandr --output DP-1 --above eDP-1
You could also add refresh-rate and resolution of the two monitors.
Take a look at this thread:
Agreed, which is why I stopped using dual monitor this year, I got tired of dealing with it resetting. Maybe dual monitor support gets better in the next release.
