Dual monitor HP Pavilion
Hey guys! i installed Zorin OS 17.3 Core yesterday, and all went well....however, the OS doesn't seem to recognise my second monitor....I read several topics in the forum to find a solution, but found none....
here my setup:
Hardware model: HP Pavillon Desktop 590
memory: 16 GIB
processor: AMD A9-9425 radeon r5, 5 compute cores 2c + 3g x 2
graphics: STONEY (stoney, LLVM 15.0.7, DRM 3.57, 6.8.0-60-generic)
disk capacity: 1.1T
OS name: Zorin OS 17.3 Core
OS type: 64-bit
Windowing System: Wayland
any help or support would be greatly appreciated, as I am new to the Linux world, but I eager to learn how to fix this and make my second screen work!
Both ny screens are Dell 17''..... was all working fine when i was on window 10....I'm sure I'm missing something simple... :slight_smile:
If secure boot and fast boot in your BIOS are enabled, please take them off.
If you have dualboot with Windows also turn off fast startup in Windows.
You could try to switch to Xorg (reboot and then when loginscreen appears, click on your username, a cog icon on the screen is displayed and there you can set "Zorin desktop on Xorg).
When Xorg is installed you can use xrandr (a terminal program to set up multiple monitors) or install arandr (this is a gui for xrandr) to manage monitors.
Also check the cables (some only function in one direction).
hey! thank you for your help! i've done all you mentioned (boot bios disable, no dualboot with windows, i switched to Xorg and in terminal this the message i got:
-$ xrandr
Screen 0: minimum 320 x 200, current 1280 x 1024, maximum 16384 x 16384
DisplayPort-0 connected primary 1280x1024+0+0 (normal left inverted...)
1280x1024 60.02*+ 75.02
1280x800 60.02
1152x864 75.00
HDMI-A-0 disconnected (normal left inverted right x axis y axis)
Hi and welcome.
As Zorin 17 is a fork of Ubuntu 22.04 I used that in my search criteria that came back with this:
HP Pavilion 590 Dual Monitor Issue
The HP Pavilion desktop 590 p0024 has been reported to have issues with dual monitors not working correctly under Ubuntu 22.04. Users have encountered problems where only one monitor is detected, and the second monitor does not function as expected.4 This issue might be related to the hardware capabilities of the system, as some users have suggested that the VGA port might be phased out, and the motherboard may not support both HDMI and VGA simultaneously.4
For users experiencing similar issues with Ubuntu 22.04, it is recommended to check for updates and ensure that the system is up to date, as this can sometimes resolve display detection problems.6 Additionally, updating the BIOS and graphics drivers can also help in resolving such issues.4 If the problem persists, it might be necessary to consider installing a dedicated GPU card to support the second monitor, especially if the onboard graphics are not sufficient.4
If you are facing issues with multiple displays not working correctly after an upgrade to Ubuntu 24.04, some users have found that configuring the xorg.conf file with the appropriate BusIDs for the graphics cards can resolve the issue, allowing both displays to work correctly.1 However, this solution is specific to Ubuntu 24.04 and may not apply to Ubuntu 22.04.
askubuntu.com
nvidia - After Ubuntu 24.04 upgrade multiple displays not working - Ask Ubuntu
askubuntu.com
nvidia - Ubuntu 22.04 External monitor not detected - Ask Ubuntu
askubuntu.com
drivers - External monitor not detected on Ubuntu 18.04 - Ask Ubuntu
h30434.www3.hp.com
Dual monitor in hp pavilion desktop 590 p0024? - HP Support Community - 7224336
help.ubuntu.com
Connect another monitor to your computer
ubuntuforums.org
[SOLVED] Ubuntu 22.04. Just
thank you for sharing! my HP is a pavillon 590-a0xxx, and dual monitors worked fine with window 10 without changing anything...i guess there is a solution....but so far I can't find it....
Is this your second monitor?
Some HDMI cables are One Direction Only. If reversed, it won't work. Since the time it worked on Windows, has that monitor been disconnected and reconnected, reversing the cable?
hello! yes HDMI-A-0 it is the second monitor, and I didn't disconnected, reconnected or reverse the cable, all i did is installed Zorin .... i didn't touch any hardware
I would check the cable is secure, just in case something inadvertently got tugged.
In the meantime, what is your terminal output for
lspci -k | grep -EA3 'VGA|Display'
00:01.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Stoney [Radeon R2/R3/R4/R5 Graphics] (rev da)
Subsystem: Hewlett-Packard Company Stoney [Radeon R2/R3/R4/R5 Graphics]
Kernel driver in use: amdgpu
Kernel modules: amdgpu
Can you try to force EDID recognition? (Assuming your second monitor is to the right like mine is...):
xrandr --output HDMI-A-0 --auto --right-of DisplayPort-0
nothing is happening ... :thinking:
Can you unplug and replug in the monitor, and the power cord to the monitor, then run
xrandr
jonh13@HP-Pavilion-Desktop:~$ xrandr
DisplayPort-0 connected primary 1280x1024+0+0 (normal left inverted right x axis y axis) 338mm x 270mm
1280x800 60.02
1152x864 75.00
1280x720 60.02
1024x768 75.03 60.00
800x600 75.00 60.32
640x480 75.00 59.94
720x400 70.08
If this was me, I would suspect a faulty cable.
You are showing the correct amdgpu driver and xrandr is working properly.
Either the monitor itself is not sending the correct EDID or the cable is bad.
You might switch the two monitors HDMI cables to test this...
ok, im gonna try now to change the HDMI cable....all worked fine with window 10 yesterday....
you're a star :1st_place_medal:
changing the HDMI cable activated the right screen....
you must understand the linux/zorin environment very well to have guessed that....bravo
Screen 0: minimum 320 x 200, current 2560 x 1024, maximum 16384 x 16384
1280x800 60.02
1152x864 75.00
1280x720 60.02
800x600 75.00 60.32
640x480 75.00 59.94
720x400 70.08
HDMI-A-0 connected 1280x1024+1280+0 (normal left inverted right x axis y axis) 376mm x 301mm
1280x800 60.02
1152x864 75.00
1280x720 60.02
800x600 75.00 60.32
640x480 75.00 59.94
720x400 70.08
