Dual Monitors with Docking Station
I've got a Toshiba Dynadock U3.0 docking station. I've just hooked it up to my computer and connected to a single monitor but nothing is being displayed. I actually have two monitors I want to connect to but thought I'd try one first.
I'm wondering if there are any drivers or software I may need to install or if it's even possible for the dock to work with dual monitors on the computer.
Do you have the Display Link drivers installed?
https://support.displaylink.com/knowledgebase/articles/1944022-how-to-install-displaylink-software-on-ubuntu-20-0
I have tried to, but when I do I get errors connecting:
Do you want to continue? (Y/n) Y
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
Reading package lists...
Building dependency tree...
Reading state information...
  adwaita-qt libxmlsec1 libxmlsec1-nss
  libpciaccess-dev
  libdrm-dev libpciaccess-dev
0 upgraded, 2 newly installed, 0 to remove and 2 not upgraded.
Need to get 151 kB of archives.
After this operation, 780 kB of additional disk space will be used.
Err:1 http://archive.ubuntu.com/ubuntu focal/main amd64 libpciaccess-dev amd64 0.16-0ubuntu1
  Connection failed [IP: 185.125.190.36 80]
Ign:2 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 libdrm-dev amd64 2.4.107-8ubuntu1~20.04.2
Err:2 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 libdrm-dev amd64 2.4.107-8ubuntu1~20.04.2
  Connection failed [IP: 91.189.91.38 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libp/libpciaccess/libpciaccess-dev_0.16-0ubuntu1_amd64.deb  Connection failed [IP: 185.125.190.36 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libd/libdrm/libdrm-dev_2.4.107-8ubuntu1~20.04.2_amd64.deb  Connection failed [IP: 91.189.91.38 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Unsatisfied dependencies. Missing component: libdrm.
This is a fatal error, cannot install DisplayLink Linux Software.
Hmmm...
In the meantime, it looks as though you need to run (for some other things noted in your terminal):
Thanks - I have run those commands, however when trying to do the update it fails, it always seems to fail whenever I try to update:
Hit:1 https://dl.google.com/linux/chrome/deb stable InRelease
Hit:2 https://packages.zorinos.com/stable focal InRelease
Hit:3 https://packages.zorinos.com/patches focal InRelease
Hit:4 https://packages.zorinos.com/apps focal InRelease
Hit:5 https://packages.zorinos.com/drivers focal InRelease
Hit:6 https://packages.zorinos.com/premium focal InRelease
Err:7 http://archive.ubuntu.com/ubuntu focal InRelease
  Connection failed [IP: 185.125.190.39 80]
Err:8 http://ppa.launchpad.net/zorinos/apps/ubuntu focal InRelease
  Connection failed [IP: 185.125.190.52 80]
Err:9 http://packages.microsoft.com/repos/code stable InRelease
  Connection failed [IP: 13.80.99.124 80]
Err:10 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Err:11 http://ppa.launchpad.net/zorinos/drivers/ubuntu focal InRelease
Err:12 http://archive.ubuntu.com/ubuntu focal-backports InRelease
Err:13 http://ppa.launchpad.net/zorinos/patches/ubuntu focal InRelease
Err:14 http://archive.ubuntu.com/ubuntu focal-security InRelease
  Connection failed [IP: 91.189.91.39 80]
Err:15 http://ppa.launchpad.net/zorinos/stable/ubuntu focal InRelease
Reading package lists... Done
2 packages can be upgraded. Run 'apt list --upgradable' to see them.
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal/InRelease  Connection failed [IP: 185.125.190.39 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-updates/InRelease  Connection failed [IP: 185.125.190.36 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-backports/InRelease  Connection failed [IP: 91.189.91.38 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-security/InRelease  Connection failed [IP: 91.189.91.39 80]
W: Failed to fetch http://packages.microsoft.com/repos/code/dists/stable/InRelease  Connection failed [IP: 13.80.99.124 80]
W: Failed to fetch http://ppa.launchpad.net/zorinos/apps/ubuntu/dists/focal/InRelease  Connection failed [IP: 185.125.190.52 80]
W: Failed to fetch http://ppa.launchpad.net/zorinos/drivers/ubuntu/dists/focal/InRelease  Connection failed [IP: 185.125.190.52 80]
W: Failed to fetch http://ppa.launchpad.net/zorinos/patches/ubuntu/dists/focal/InRelease  Connection failed [IP: 185.125.190.52 80]
W: Failed to fetch http://ppa.launchpad.net/zorinos/stable/ubuntu/dists/focal/InRelease  Connection failed [IP: 185.125.190.52 80]
W: Some index files failed to download. They have been ignored, or old ones used instead.
Calculating upgrade... Done
The following packages will be upgraded:
  code distro-info-data
2 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
Need to get 88.5 MB of archives.
After this operation, 54.3 kB disk space will be freed.
Do you want to continue? [Y/n] Y
Ign:1 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 distro-info-data all 0.43ubuntu1.12
Err:2 http://packages.microsoft.com/repos/code stable/main amd64 code amd64 1.77.1-1680651665
Err:1 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 distro-info-data all 0.43ubuntu1.12
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/d/distro-info-data/distro-info-data_0.43ubuntu1.12_all.deb  Connection failed [IP: 185.125.190.39 80]
E: Failed to fetch http://packages.microsoft.com/repos/code/pool/main/c/code/code_1.77.1-1680651665_amd64.deb  Connection failed [IP: 13.80.99.124 80]
What I am seeing in your post is a lot of connection loss. If it was just one site losing connection, I would think it was that site.
But you show them across multiple sites.
Have you rebooted your router recently?
Check your traceroute for packet loss or signal drop.
May i also add, make sure your docking station is Linux Compatible.
Can you provide the Make & model of the docking station Please.
It's a Toshiba Dynadock U3.0.
I'll try and and reset the router and maybe a different network.
Sorry i'm not online for long.
It seems it maybe only windows compatible.
Please try to research this further to verify this.
They do offer drivers:
https://support.displaylink.com/knowledgebase/articles/683482
I finally managed to get the Display Link driver installed after days of trying various things.
Unfortunately still nothing displayed on screen. :weary: I've contacted Toshiba but don't hold out much hope.
On that note was wondering if anybody knew of any decent docking stations that would be compatible out of the box with Zorin. I've purchased two monitors which have DVI connections. I can currently connect to one directly via a HDMI cable and DVI adaptor but would like to be able to connect to both. I just have a single HDMI port on my laptop. I also need it to be compatible with Windows as I switch between machines. Ideally something I could pick up fairly cheap second hand would be ideal since I've already wasted money on the Dynadock :rofl: cheers
Glad to see you got the drivers running.
Are you able to try the monitor that you maybe having trouble with the HDMI to DVI adaptor, via just using the DVI output on the Docking device, does this work?
Why i ask is i also have a DVI (Samsung) monitor, which works 100% with DVI, but when i try via HDMI from pc to DVI adaptor at the monitor end, I get no signal.. I'm have never investigated the issue, i assumed the adaptor was faulty, It maybe a directional sensitive adaptor.
Sorry for the delay, no I tried the DVI and that doesn't work either so maybe you do have a faulty adaptor.
I have now purchased another docking station that I found on a 'Best docking stations for linux' article, a Dell D3100.
I again had problems with it and with the drivers and something called Evdi that required installing for it to work. Not quite sure what happened but I think something went wrong installing because I then tried to upgrade my kernel and it installed with errors. Then the PC wouldn't boot up. Eventually managed to get it working again by going to advanced options and booting with the old kernel, then managed to remove the new (badly installed) kernel and seems fine now. Now a bit wary about upgrading to the new kernel so think I'll just avoid upgrading for a while.
It now tells me that the displaylink driver is installed:
displaylink-driver is already the newest version (5.7.0-129)
It also tells me the service can't be found:
systemctl status displaylink.service
Unit displaylink.service could not be found.
Still nothing when I connect either docking station. Think I am going to give up and be resigned to one monitor forever as I don't really know what I'm doing on linux machines and don't want to completely break my PC as it's a work computer!
