lol I forgot about this question.
Let me get this straight, the .xml file that I gave you had "unnecessary" transitions. I have deleted them and made a new one. If you want, I can give it to you. If you want to make them do 20+ images, you may repeat the commands. But change the duration value. I feel like the duration value is set to a particular value so that the slide show will last for a day. So you should add all the duration values and then divide it by the number of pictures you are going to add and then give that value to each of the duration elements. Or you could Give different value to each duration elements but make sure that they add up to the sum of all the values duration elements in the file I gave you. Now that's a lot of work. But it will be worth it.
