Edimax 7811UN first working fine and becomes unusably slow
Hi all,
I have installed Zorin Core on my old MacBook Pro (dual boot) which has a faulty wifi, hence I've been using Edimax 7811UN wifi adapter. The adapter runs fine when I boot to MacOS but is very unstable and unusably slow on Zorin 17.1. It was initially working fine actually and I started having issue with it on day 3 after installing Zorin.
I wonder if there is better driver I could install and use. Here is some output that might help you to help me :slight_smile:
$ sudo lshw -C network
*-network
       physical id: 8
       bus info: usb@3:1
       logical name: wlx74da388c3b92
       serial: 74:da:38:8c:3b:92
       capabilities: ethernet physical wireless
       configuration: broadcast=yes driver=rtl8192cu driverversion=6.8.0-40-generic firmware=N/A ip=192.168.68.85 link=yes multicast=yes wireless=IEEE 802.11
$ sudo dmesg | grep -i wifi
[    6.916582] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw_TMSC.bin
[  100.687719] UBSAN: array-index-out-of-bounds in /build/linux-hwe-6.8-dKyDY4/linux-hwe-6.8-6.8.0/drivers/net/wireless/realtek/rtlwifi/rtl8192cu/trx.c:502:15
[  100.688097]  rtl_op_tx+0xcc/0xf0 [rtlwifi]
Thank you in advance.
Updates. At one point when wifi won't connect at all after laptop went on sleep mode, I got this:
[11508.260105] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw_TMSC.bin
[11543.598491] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw_TMSC.bin
[11641.582365] workqueue: rtl_watchdog_wq_callback [rtlwifi] hogged CPU for >10000us 4 times, consider switching to WQ_UNBOUND
[11714.834562] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw_TMSC.bin
I see You are using the 6.8 Kernel. Please go to the GRUB Menu, click there on ''Advanced Options'' and choose there the 6.5 Kernel to test if it better runs.
Hi @Ponce-De-Leon thank you for your response. I am using 6.8 kernel. It seems the issue is intermittent, and it was working fine before I switch to 6.5. I think I need to work in 6.5 for a period of time to see if this is more stable.
Just want to ask, should I be concerned over the index out of bound here, which also happens in 6.5
[   19.267568] UBSAN: array-index-out-of-bounds in /build/linux-hwe-6.5-X9ca7v/linux-hwe-6.5-6.5.0/drivers/net/wireless/realtek/rtlwifi/rtl8192cu/trx.c:502:15
I wonder if anything here would help you re rtl8192cu wifi.
...but the item is OLD.
Maybe worth a websearch using searchterm: "rtl8192cu ubuntu 22.04"
It looks for me that it is an Driver Issue. The Question is: It is a problematic and/or Security relevant Driver Issue ... For this I'm not competent enough.
I did try that rtl8192cu driver before I created my post here. But the make process was failed. I think it wasn't compatible.
And after using Kernel 6.5, it seems it is more stable than 6.8. It's good enough for me for now ... so I will keep using 6.5.
