Hi all.
I would like to make a entry in file explorer pointing directly to a drive/folder I have in my laptop.
How could I proceed?
thank you
Hi all.
thank you
You could try to draw the Drive/Folder to the left. Then it should be appear under the normal Categories.
draw...???
I think drag was meant, not draw...
Browse to folder/location within your drive. Drag to just under Trash to create a New Bookmark.
Is ''draw'' not a suitable Word? Did DeepL lied to me? Okay I try it in a different Way:
Move with Your Mouse Cursor the Icon from Your Drive/Folder from the right Side to the left Side. You see that it will show under the normal Category Entries (look at the Picture from @wboy).
P.S.: Welcome to the Forum @wboy! And thanks for Your Help.
Thank you!
That's handy. ![]()
