As you could see the spacing between the items in the default gnome shell extension items is not equal. I would like to have this similar to Windows.
The space between cpu-manager, zorin-connect & clipboard is different from system tray icons which are neat. I downloaded caffeine also but it looked ugly with its own irregular spacing. So, I removed it.
Is there a config file to modify spacing or preferably an extension that I could use to tuck all those in a box?
to something like below where downloaded extensions should go into the
The fact that they don't place inside the system tray is normal, that's the tray exclusively for system icons, while extensions icons are loaded into separated trays. If you want to place them on the system tray anyway, I found KDocker and AllTray on Software Center if you want to try something.
