I got in grub the message that there is a usb error -32 and I just waited and ignored it and it booted anyway. But on usb my mouse didn't work I have a Logitech G402 and it's in a Motherboard slot. I was thinking maybe the install will fix it, cause my Laptop couldn't use Bluetooth before install. So I install same problem still. First Linux with this Problem I used and tried. I tried manjaro one week ago no issues at all. I use Windows still btw.
Also tried 2 different mouses aswell and other linux "fix" stuff in the terminal nothing changed.
hello V.D.K welcom to the forum,
Do you have Zorin installed, perhaps as dual boot? Or are u booting the iso file from an usb?
Could you give us the output of lspci?
Possible a corrupt installation ? Did you verify the .iso ?
I agree. With such a fresh installation, I would try a Reinstallation of Zorin OS.
You may try ensuring that The top four boxes are ticked to ON in Software & Updates then opening a terminal and running
Other than that, reinstall Zorin, it looks like something went wrong During Installation. Ensure that the "install 3rd party drivers box" is ticked to ON.
Marked solution. 71
