Yes, in the Software Center I had deleted the flatpak version of Boxes, and attempted to install the distro version (wanted USB redirection). The install of the distro version failed, so I went to the terminal, did a sudo apt update, upgrade, and got my first error. Continued on with an apt install gnome-boxes, got a message that most current version was installed, and got the lvm2 etc error message.
Boxes is installed, and working, so not sure why the software center install failed.
$ sudo rm /etc/lvm
rm: cannot remove '/etc/lvm': Is a directory
marcs@marcs-HP-ENVY-Desktop-795-00xx:~$ sudo apt remove lvm2
Reading package lists... Done
Building dependency tree
dmeventd libdevmapper-event1.02.1 libgmime-3.0-0 liblvm2cmd2.03 libmessaging-menu0 libreadline5
linux-headers-5.13.0-41-generic linux-hwe-5.13-headers-5.13.0-41 linux-image-5.13.0-41-generic
linux-modules-5.13.0-41-generic linux-modules-extra-5.13.0-41-generic thin-provisioning-tools
The following packages will be REMOVED:
lvm2
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 3,953 kB disk space will be freed.
(Reading database ... 367276 files and directories currently installed.)
Removing lvm2 (2.03.07-1ubuntu1) ...
Processing triggers for man-db (2.9.1-1) ...
marcs@marcs-HP-ENVY-Desktop-795-00xx:~$ sudo apt install --reinstall lvm2
libgmime-3.0-0 libmessaging-menu0 linux-headers-5.13.0-41-generic linux-hwe-5.13-headers-5.13.0-41
linux-image-5.13.0-41-generic linux-modules-5.13.0-41-generic linux-modules-extra-5.13.0-41-generic
lvm2
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/1,053 kB of archives.
After this operation, 3,953 kB of additional disk space will be used.
Selecting previously unselected package lvm2.
(Reading database ... 367139 files and directories currently installed.)
Preparing to unpack .../lvm2_2.03.07-1ubuntu1_amd64.deb ...
Unpacking lvm2 (2.03.07-1ubuntu1) ...
Setting up lvm2 (2.03.07-1ubuntu1) ...
update-initramfs: deferring update (trigger activated)
Failed to restart lvm2-lvmpolld.service: Unit lvm2-lvmpolld.socket is masked.
invoke-rc.d: initscript lvm2-lvmpolld, action "restart" failed.
● lvm2-lvmpolld.service - LVM2 poll daemon
Loaded: loaded (/lib/systemd/system/lvm2-lvmpolld.service; static; vendor preset: enabled)
Active: inactive (dead)
Docs: man:lvmpolld(8)
dpkg: error processing package lvm2 (--configure):
installed lvm2 package post-installation script subprocess returned error exit status 1
Processing triggers for systemd (245.4-4ubuntu3.17) ...
Processing triggers for initramfs-tools (0.136ubuntu6.7) ...
update-initramfs: Generating /boot/initrd.img-5.13.0-48-generic
lvm2
