Hello, i hope you help me, After installing zorin os 15.3-Lite clean install not dual boot, after installing it. a black screen appeared with a message, "No Bootable Device". in BIOS, I don't have any option for changing from UEFI to Legacy and there is no Secure Boot option. - i use RUFUS to burn the iso file of zorin this is what i did after to find a solution but nothing works:
1:Boot the Zorin OS USB Install Drive
2:open Terminal: entering this commands;
sudo mount /dev/sda1 /mnt
cd /mnt
ls
but when i type cd /EFI ; error appeared NO directory
Given that you are using Zorin OS 15.3 Lite, is the machine a 32 bit machine?
It may be that it is supporting MBR and since you cannot change that, you may need to burn the .iso on the USB stick as MBR. Rufus does have that option under Drive Properties > Partition Scheme. Select MBR from the Drop Down menu.
i already did it mate. but when i press F10 to check boot drive without entering bios i can't see my drive HDD but in BIOS i can see it.
i hope you can understand me
Agreed that it is no bother. This helpdesk is here for this purpose.
The next things I would suggest would include a S.M.A.R.T. test of the drive to see if it has bad sectors or blocks that corrupted. You may try a fresh Download of the .iso, fresh burn on a different USB stick to eliminate any download corruptions, burn corruptions or USB stick failures.
Was the disk working normally prior to the installation of Zorin OS? For example, did it have a different installed OS that booted normally?
