run sudo apt clean
run sudo apt autoremove
run Sudo apt update
I have tried running FSCK not having problems. What do I have to do? Thank you.
run sudo apt clean
run Sudo apt update
What happens when you just enter:
sudo apt clean
Something has corrupted in the lists. Can you remove them:
sudo rm /var/lib/apt/lists/*
Check your Sources.list for any duplicate entries using Software & Updates.
Then run
sudo apt update && sudo apt clean && sudo apt autoremove
thanks for the help, it's back to normal.
