Error when using two monitors with my dedicated graphics [AMD Radeon rx 580 SP]
Hello,
I am experiencing an issue with my Zorin OS 17 setup and would appreciate some assistance. Here are the details of my system:
  • AMD Radeon RX 580 SP
  • Intel i5 (8th generation) with integrated graphics
When I connect my monitors as follows, everything works fine:
  • One HDMI connected to the motherboard (using Intel graphics)
  • One HDMI connected to the dedicated graphics card
In this configuration, I can move screens, change the primary monitor, and everything functions correctly. However, I encounter a strange problem that I do not experience in Windows.
When I connect both monitors to my dedicated graphics card (one via HDMI and the other via DisplayPort), one of the monitors (the one connected via DisplayPort) intermittently disconnects and reconnects. This issue is particularly annoying because it requires me to switch ports each time I boot into Windows or Zorin (dual boot setup). Additionally, when I use HDMI on both Intel and AMD, it shows that only the Intel graphics are being used.
I am looking for a solution to prevent this from happening.
Thank you for any assistance you can provide.
