Errors installing samba
I tried to install samba using:
sudo apt update
sudo apt install samba
Giving:
Error! Bad return status for module build on kernel: 6.8.0-83-generic (x86_64)
Consult /var/lib/dkms/rtl8821cu/5.4.1~ppa/build/make.log for more information.
dpkg: error processing package rtl8821cu-dkms (--configure):
installed rtl8821cu-dkms package post-installation script subprocess returned e
rror exit status 10
rtl8821cu-dkms
So I tried:
sudo apt update
sudo apt install samba cifs-utils
That gave:
rror exit status 10
rtl8821cu-dkms
I then tried:
sudo apt --fix-broken install
Followed by:
But I am still getting the same errors.
Can you help please?
I am running Zorin OS 17.3 Core
On a Dell OptiPlex 390
Intel® Core™ i5-2400 CPU @ 3.10GHz × 4
8GB memory
Did You add any Third-Party Repo's? When You type in Terminal sudo apt update what Output do You get?
This seems to be a Problem. I guess this is a Driver Package. When You type sudo apt install rtl8821cu-dkms does it work?
Hello and thanks for the reply.
sudo apt update
Gives:
Fetched 13.6 MB in 5s (2,936 kB/s)
Reading package lists... Done
14 packages can be upgraded. Run 'apt list --upgradable' to see them.
Gave:
rror exit status 10
rtl8821cu-dkms
I don't know what rtl8821cu-dkms. I will search and be back.
DUH!! Just found it, it is the driver for my (now unused) USB WiFi adaprter. I Will try to remove it and report back.
Removed the drivers and now installs without error.
Many thanks
