estou com um adaptador wifi6 mas no sistema zorion 18 basic nao reconhece /media/victor/WIFI driver/Wifi6_install.exe
Wifi6 is not well supported on GNuLinux.
To obtain support, the manufacturers must release the drivers - and they sometimes don't or release incomplete files.
Is this your only available wifi hardware?
Could You post the Output of sudo lshw -C network please? It shows Your Network Stuff so we can see what Components these are.
Hi, the .exe files aren't valid unless you run them with Wine. I recommend searching for your model on GitHub, but I'm warning you now, as the developers have mentioned, that neither Wi-Fi 6 nor Wi-Fi 7 will work well, from what I've read, unless they're private projects. I've read that there's a TP-Link Wi-Fi 5 nano USB adapter for Linux; it costs about $11. They also say that MediaTek adapters are compatible.
