Hello I'm having the exact same issue. My Ethernet worked then stopped. Then two days ago I booted the machine and it was working. Now it's out again. It was fine at first install and has worked perfectly for months till recently. So I'm pretty sure an update killed the connection. Wi-Fi still works. I can't understand why Ethernet was working but was intermittent.
My PC is an older HP P7-1534 AMD A8-5500 16 GIG RAM all BIOS and firmware up to date. System is NOT dual boot and was a fresh install of 16 PRO on a new Samsung SSD. Secure boot is currently disabled. It's been a while since I did the install but I'm pretty sure I disabled it prior to install.
The system was working fine with both Ethernet and wi-fi. Spectrum Cable modem with separate wi-fi router. Both have been rebooted in attempts to solve this issue without success.
The machine has been working perfectly since the install months ago. Only within the past two to three weeks has this issue appeared. I thought it might be my hardwired connection but it checks out fine with my Windoze laptop.
Last weekend when I booted up the machine the Ethernet connected right up. The next day it didn't and hasn't since. No repairs done to the machine. However the secondary HDD was replaced by me with an SSD a few months back but the machine worked fine after that.
Since my lshw-C multimedia looks good. I'm at a loss as to what's going on. Also this is my first Linux box so maybe I'm missing something? I still can't help but feel an update of some type caused this.
Can you please boot into the Grub Menu, either by tapping esc or tab at boot.
Select Advanced Options for Zorin and choose to boot Zorin OS on an earlier kernel (perhaps the -56 or -76).
Once booted, test the Ethernet connection.
my choices are
5.15.0-82 generic and generic recovery
5.15.0-79 generic and generic recovery
I tried booting to both versions using the "generic" option and the result is the same. No Ethernet connection.
I do have timeshift installed and did a snapshot on 07/05/2023 the Ethernet connection was working at that time. Do you think I should I try and restore that snapshot?
I did that and rebooted with no success. When I run the uname -r I get this. Don't worry about the run around. After using Windows for decades I'm used to run arounds and frequent re-installs
*** I ask because previous versions of the driver were sometimes installed and started force disabled (toggled off). ***
I wonder if that's what happened. The wired connection tries to connect, gives an unable to connect message then toggles itself off with any user input.
Well it's getting late here so I'll sleep on it and try again tomorrow. Thanks to all for your help. Keep posting and I'll try suggestions again tomorrow.
Cable and connection to router is good works fine with my windows laptop. Zorin shows wired as trying to connect then fails to authenticate and toggles the wired connection off.
Wired details shows the correct hardware MAC address according to PC BIOS but for last used it says NEVER which is surprising as it worked in the past.
When I purchased the PRO version I used the download link provided and then as instructed I used the Upgrade Zorin OS from the System Tools menu. I just now tried to run it again but it says I've already upgraded to 16.3.
I have a spare tower that is the exact same machine. Just to see, I tried to install the latest version of MINT on a blank Samsung ssd and encountered the exact same error of not being able to connect to the wired network.
So the same error with two different versions of Linux tells me it's a driver issue within the OS as the hardware checks out fine. Very Strange.
Well I'm out of town for a couple days. I'll work on it some more when I get back. In the meantime can any reccommend a network card that has built in drivers that work in Zorin? It's lookin like I might have to install a new card .
Actually, HWE updated about a week ago to 5.15.0-82, I believe.
How did you test the hardware?
The same error with two different versions of Linux may actually have two different drivers.
Accordingly, the Atheros AR8161 is an older card and very strongly supported:
It could be a driver issue - or it could be that when the HWE kernel was upgraded, the modules got moved to the HWE stack and that is where the issue is.
But I do not see any reason mentioned here to rule out the hardware or another cause just yet...
** How did you test the hardware?**
The hardware shows in BIOS and address in Zorin matches that address. It originally worked when this was a windows machine and when I installed Zorin and I wiped the drive prior to a clean install. It also worked one time on startup and was fine but upon the next restart failed again. This was after the upgrade to 16.3. I guess it's possible the hardware failed ,but in two identical machines with different Linux OS's? Not saying that couldn't happen but the odds...
When the issue first showed up I did a google search of "Atheros AR8161 Linux issues" brought up a multitude of people having problems with running the card on different distros. Many have not had success with getting the Ethernet access back. My wi-fi which uses the Realtek chip set works flawlessly. So I do have web access but slower than my hard wire so I'd like to find out why the hardwired connection is not working.
So if the modules did get moved to the HWE stack, how do I proceed?
If this is two machines with the same hardware - I agree completely that the odds are slim that both pieces of hardware failed, at the same time.
Much more likely the drivers.
I actually tried this above with the
That reinstall command should have done the trick if such was the case.
Which brings us to:
Me too.
Not unusual for me to get stumped, though. Will keep researching this to see if I find anything...
