like the title says every time i try to connect the Bluetooth headphones via the settings menu it crashes the software it is not the hardware because it worked fine on windows is there a hidden setting or missing packet i need to install if you lot can help me if you can thanks
Can you please post the output of
sudo lshw -c network
Hey, I have this same issue but looks like the opener didn't respond. Heres my output from sudo lshw -c network
[sudo] password for aklusa:
*-network
product: Wi-Fi 6 AX200
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:02:00.0
logical name: wlp2s0
version: 1a
serial: b4:0e:de:13:a1:6e
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=5.17.4-051704-generic firmware=66.f1c864e0.0 cc-a0-66.ucode ip=192.168.1.12 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:71 memory:fc700000-fc703fff
This appears to happen on Windows, too:
This makes it likely a Firmware issue.
