How to set Exaile as the default player;
When inserting CD, at the top of the screen, the only option is Rhythm Box.
ejected CD, opened Exaile, re-inserted CD... nuttin'
While this is more of an Exaile. org issue,
How to set Exaile as default player... as well as "what to do" when Audio CD is inserted.
fwiw, Audio CD is DSD- hybrid... does Exaile "recognize" as much (vs. "wav".)
You can right click on any filetype for music, for example, if you have a file named song.flac, and select Open with
From here select "Other application"
A Popup window will appear with a list. Select exhaile from the list, then click the button at the bottom for "Make default" or "Set as default" for this filetype.
Thank you...
also posted regarding moving "default" music folder to a different (i.e. /dev/nvme1n1) drive... as the downloaded player/ripper defaults to Zorin-installed music folder... music collection to larger drive (other than drive with OS installed)
...have not, yet, ripped any tracks to nvme1n1.
Tried right-click drag-and-drop music folder to mounted nvme1n1 partition...
nuts.
Still working with left over Win10 days parts; should have saved myself the headaches, bought a larger nvme... and tossed the last two in the microwave.
Thank you...
nuts.
