The laptop suddenly freeze and I don't know why
for example here I just wrote the word (with), however my keyboard is totally fine.
I'm unable to select my Graphics card, I have an ASUS TUF A15, RTX 3050 mobile. and it doesn't say that in the system info. And I tried everything to install the drivers.
For using the Nvidia Card You could try it with the Terminal Command sudo prime-select nvidia
For installing the Drivers: When You go to Software & Updates and there to the ''Additional Drivers'' Tab what is shown to You? Maybe You could make a Screenshot and show it here.
The Freezing: There would be the Question that aravision ask: Do You have the new 6.8 Kernel installed? It makes some Issue at the Moment. To control that open the Terminal and type uname -r
The Kernel Version is in this Case important for the Driver Choice, too. So, it is good to know which Kernel do You use.
Another Things for Freezing: Do You use Fractional Scaling? How is Your Refresh Rate set up? And when You want to use Your Nvidia Card take care that Your System is running with Xorg and not with Wayland. To control that, You can go in the Settings and there to the ''About'' Tab. There look where ''Window Manager'' stands.
Fractional Scaling is in the Display Settings. But when you don't know about it, it shouldn't be activated.
Because of the Drivers on your first Picture: When You installed Zorin, did You have chosen the Option to install it with modern Nvidia Graphics? If yes, that would it explain because it would have installed a newer driver than what stands on this List.
Because Your System is running on Wayland: You should change that and test if it runs better. To do that go to the Login Screen and click on Your Profile so that the Password Field appears. It must be appeared! When it is appeared, you should see in the bottom right Corner a Gear Icon. Click on it. You should see 2 Options:
Zorin Desktop
Zorin Desktop on Xorg
What is active you can see at the Dot Marker at the Beginning. So, choose the Xorg Option and log in and test if it runs better.
No, it stays until You change it back. It doesn't change automatically back.
With the Edge Thing unfortunately I can't help You. I don't use Edge and I don't have a Laptop.
Then You should have installed the 550 Driver. This isn't shown in the List. You could control if the driver is installed with the Terminal Command apt list nvidia-driver-550
Yesterday I shut down the laptop and everything was working fine.
Today, I turned the laptop on and the scrolling with the touchpad was different and some gestures weren't there any more. Also the dock at the bottom wasn't behaving as before it's an extension called (Dash to Dock)
Also most importantly, the speed of my touchpad was very fast and the settings weren't beneficial for changing the speed.
I know Dash To Dock. What does ''wasn't behaving as before'' mean? What do it now, what it before didn't do? Or what do it now not, what it did before?
